Arlo Pro Base Connection
WiFi Connectivity
I recently purchased the Pro and want to install it at my cottage which is located in a resort community. The community is closed in the winter thus I don't have hard internet at the cottege but the resort has resort wide WiFi and I am wondering, can I connect the base to the resort WiFi or does it have the be ethernet only?
If it is possible, how?
@SherkSpad wrote:
WiFi Connectivity
The Pro base has to connect to physically to your network via a network cable. The only workaround I can think of for your situation would be if you could set up a WiFi extender that connected to your resort WiFi and which has an RJ45 connector on it. If your network connection being offline is your personal choice rather than a resort decision, you might be able to get a low cost "off-season" network connection that woud work better.
