When reading the manual for "Camera LED" settings, there should be more then one option to turn off the LED on the individual cameras. Yet, going into the devices settings to change it from On to Off I only see an option for "Battery Fully Charged Indicator", where are the other options?
Yes that's correct. What other led do you want to turn off?
the only other are the IR illuminators.... except a blinking low battery, etc( can't be turned off )
