Arlo Service Offline Again
  • 6 Replies
  • 3862 Views
ralfyguy1
Virtuoso
Virtuoso
I can log in and all 5 cameras show offline. I rebooted the base station already and all other internet devices work fine.
Streak2
Master Master
That middle light shows connectivity to the internet. Sometimes a glitch on the modem can cause this problem that a reboot will correct.
Well done for preserving.
6 REPLIES 6
Streak2
Master Master
All working fine here.
I do sometimes experience what you're seeing but it usually corrects itself when logging back in.
ralfyguy1
Virtuoso
Virtuoso
As of this morning still all cameras offline.
Streak2
Master Master
If you're using an app then try the web interface as well.
ralfyguy1
Virtuoso
Virtuoso
I was using the web based the whole time. Two different browsers. I can log in but I cannot do anything else. rebooted the modem, the router, PC etc. Android app the same. On the base station the three green lights, there is only two lit. The one in the middle is off, not even amber.
ralfyguy1
Virtuoso
Virtuoso
Update: So about 10 minutes after rebooting the modem, everything is back. But that was 10 minutes after the modem was back ONLINE, not immediately. That was really strange.
Streak2
Master Master
