Good Morning
Today, when I left, I noticed I didn't get an alert from my driveway camera. When I got to the office, I logged in via the web, and noticed that under my "mode" tab all I see active is a little clock. Normally, I keep my arlo in a "scheduled" mode as I have different cameras I arm/disarm and sensitivities that I adjust during different times of day. What I should see is the little clock next to the word "weekday" as that schedule should be active. However, all I see is the clock which is odd. I went to the devices page and noticed that the "motion man" was not lit on any camera that should be armed. I forced the mode to armed and the system armed as normal. When I go back to click "schedule", again, all I see is the clock but no mode it's running and the "motion man" is not active on any camera. Strangely, when I go to the app, and force schedule mode, it appears to show the clock - weekday and the "motion man" is lit within the app on my phone. This does not match what I see when I logon to the arlo website and my cameras are not recording in the scheduled mode even tho they should be. I double checked the schedule, all looks fine. I've made no changes to these settings in over 6 months. I've already rebooted the base but I'm still seeing the same symptom. TO me, it appears that the "schedule" mode is not working as it should at this time. Anyone else seeing this?
The 2.5.0 app update on 5/13/18 eliminated my camera recordings. The 2.5.1 update today, 5/25, did not fix the problem. When will this be fixed? I have an older device with the app version that preceded 2.5.0 and the recordings continue to appear as normal.
I have a 24 hour schedule with no gaps. When I switched to schedule mode it will initially correctly display correct mode for that time of day (ie armed) but after a while it then presents as 'disarmed' even though the rule in place should have it armed. It is doing this itself.
@netgear what is going on here? It is still not fixed. The schedule is not working. We need this fixed please.
I have a combination of geofencing and schedule rules that has worked for two years, until now.
I may be able to factory reset, rebuild everything and get it working again but at my hourly rate that is likely to cost around $400!
Arlo advertises this as a professional system, it is a shame that their development teams management are not🤨
It’s been two weeks and schedule is still not working........
Why would we have to re-synch with every update?!?! I think grade schoolers could roll out an update better then Arlo!
With all these weird scheduling bugs, loss of push notification, battery drain issue, and various other weird behavior in app (was showing s/n instead of camera name; mode screen now always shows outdated info for a few sec), I couldn’t help but imagine what happened in arlo’s engineering department......
Did you just hire a new tech lead who claimed that everything you did before he/she joined was wrong and he/she came to save the company by rewriting everything? Don’t trust that person! Everything was ok before the 5/14 update — the existing app/firmware suffered their own issues but finally stabilized to a usable state for most of us. If you could have reverted to old version, a lot of complaints on this forum will be gone.
This will only work for a few hours then it will mess up again.... Been there done that.... I did notice the web browser is working correctly, it's the app that is malfunctioning
Not sure how you got it to work with 2 minute gap. Mine does not!
A call to customer service revealed that they are well aware it’s malfunctioning and a request to“please be patient”.
its been over two weeks.........
Oh and it doesn’t matter if I try from app or web.....
If I log onto Arlo from web browser the status says schedule and Armed which is the correct mode for the time. If I log out of the web browser and into my Android app it displays schedule and disarmed or one of the other custom modes I've made.
Ok, so it’s still not working as it should.......
Does anyone from Netgear actually monitor these posts and take action???
Im done taking to India and explaining the problem a dozen times !!!
Maybe I can sell this for scrap and find cctv that’s American made with American customer service.....
Just updated to app version 2.5.2 but I’m still having the same problem.
This is getting ridiculous now!
@raider192 wrote:
@Sherlock7
Use your web browser........apps (both Android and iOS) may not display the correct active mode. They’re aware of problems and working on fixes.
Unfortunately it does not work to use the browser on my iPhone for this purpose, so right now I need to use a desktop browser to change the mode on the cameras and as I already mentioned it’s not the most convenient way.
@netgear - When will this problem be fixed??
The latest “fix” 2.5.2 seemed to work for about 15 minutes.
Now back to the new norm. When the system is supposed to be armed it’s switches to disarmed....
Getting old!
Mine is doing the same thing, the app on iphone is not showing what the browser is seeing. Also seems my "monday" on my app is missing on the schedule but it is there on the web browser. Last, scheduling does not working during the times that it says that is is on.
This is absoulty ridiculous for company of this size to put out untested software or firmware updates and have this kind of impact on its customers. In my company everything is put on beta and fully tested BEFORE it is released.
There are very few systems where this approach would be used for software distribution to a 3rd party/client. Where it is enforced the release process is made water tight to ensure these type of issues do not arise.
As a previous poster said ‘SHAME ON YOU NETGEAR’ for bringing both the profession and your own brand into disrepute.
I just finished doing a complete reset, as suggested by a previous poster.
All cameras deleted base station deleted and reset all modes and schedule recreated and it still does not work!!
Netgear support just contacted me and suggested I turn the system on and off....
Seriously! This is starting to really annoy me.
Last support person i spoke to via phone Stated the problem was on their end.
Now I get an email telling me restart my system, restart my phone etc
Everything everyone has already done!
$600 down the drain
I will be telling anyone interested not to buy this system!
Done
