Can I select an entire day of recordings to delete? If possible can you tell me step by step how to do it? At the moment I am checking numerous files then deleting. I would like to select all then delete.
Does the cloud when full then start recording over the oldest file or does it just stop an do nothing?
First you don't mention what device /app/web your using as there are a little diff on each
Second, there is no FULL any more, just rolling number of days based on your service level ( free is 7 days , On day #8, day #1 is autodeleted, etc )
On a PC it's easy
Log into Arlo via your browser, go to library, click select, then pick select all then Delete
On the Android,( and similar on Ios ) sign in, go to library and HOLD on one video... at top right two grid boxes appear
The one with the filled squares is select all ( other unselect )..so Select all then delete
On a PC it's easy
Thanks for the help. Exactly the answers I was looking for.
