Ok so I definitely feel dumb!!! Decided to create a new user name for my wife and Grant her access!!! SUCCESS!!!! Now I'm not fighting to login anymore!!!!!
A recent cloud update along with an update for the Android Arlo mobile app has been released that should resolve this issue. Please visit the app store and be sure you are up to date on the latest version of the Arlo Mobile App: Release Notes - Android App 2.4.10 - 26th March 2018
If you continue to experience this issue, please let us know.
That's always been the best way to utilize the system between multiple people. However, consider why you might want to use the fingerprint option. I tried it for a while but turned it off since the app will simply log me in without having to enter the password (it remembers). If the phone has a lock screen, why use fingerprint to access Arlo?
I'm having the same problem with the app constantly logging me out, even after just a few minutes. And there is nobody else accessing the cameras/site/app. I've gone into my settings to make sure there wasn't an errant radial checked somewhere, and nothing. this just started happening in the last week...after the network implosion.
Yes and it if reporting a flash issue many times too.
If you're getting a session times out error message and you have to log back in everytime you open the app, then go to the google play store and install the latest version of the arlo app. (version 2.4.9_20031). That should fix the issue.
I now have to log in every time I want to get online to see what's happening. Before I could log in and forget it.
If I got a notification I could click on arlo and "be there real time". Now I have to re-login and that takes time and
is not always practical. Especially if I get a notification that there is movement out the door and it's a person,
I have to log in before I can talk to him.
What has changed? Is there a fee attached to staying logged in?
Thank you for any help.
Cameras. Hope Arlo fixes the error.
No fee needed. Are you using fingerprint to log in or just username and password? The latter should log you in automatically. Perhaps reinstalling the app and/or restarting the phone would help.
The new andriod version (2.4.9_20031) actully fixed my session timed out issue. If you have android and have that version, have you tried uninstalling the app and reinstalling?
@Dclark39wrote:
Thank you for this recommendation!
Now I just have to figure out why my apps arent updating with new releases.
Your welcome.
It's google what else is new. I only have android because the Samsung S8 is the best phone out there, but I really dislike google and android. Windows 10 on my S8 would be perfect for me. Anyway check your play store settings. Auto update and notification settings are in the play store settings menu.
If you're on Android....... go to the play store and install the latest Arlo app (version 2.4.9_20031). Thta will fix the session tmes out issue and/or having to log in everytime.
Go to the play store and download the latest version. (2.4.9_20031). If you already have that version, uninstall and reinstall the app.
yes, I did that several times. Also if you search the board "Session Expired" , you will see that others started that post on 3/15 as I did. I called Arlo , have a case number. Was told to call back in a couple days for resolution. In searching the board, this has happened in May and July 2017.
If I turn off/on my phone, the apps come back as normal-go figure. I even tried it on my other (later model) smartphone-same results.
Can only hope when I call on 3/17, Arlo has an answer
My Arlo Pro system with 5 cameras has workrd fine for months. But for the last several weeks my system keeps timing out and I have to keep logging in. Any sggestions would be appreciated.
Now that I have my system back up and running now iam having trouble with the app as it keeps saying "session time out you must log in" but the app is not logged out but it will not work till I log it out then log back in. I have the latest 2.4.9_20031 app I even un-installed and re-installed still the same issue.
Join the club. Its not just you. You'll see that a number of people are having the issue over the last 2-3 days and the PR side of Netgear is MIA. Sorry for not haivng and answer.
Yeah I know what happened to all the mods, admins and reps? JamesC anybody?
