have 5 cameras set up, but cannot stream or live view on android 8.0????
I also run Android 8 with no problem.
Try and stream using the web interface https://arlo.netgear.com to eliminate a local problem, if that works then re-intsall the Android app.
If it does not work then restart the base.
Thanks, now works great
