  • 2 Replies
  • 83387 Views
rssr725
have 5 cameras set up, but cannot stream or live view on android 8.0????
Streak2
Master Master
I also run Android 8 with no problem.
Try and stream using the web interface https://arlo.netgear.com  to eliminate a local problem, if that works then re-intsall the Android app.
If it does not work then restart the base.
Streak2
Master Master
rssr725
Thanks, now works great
