Has arlo removed the siren from arlo pro? The pull down alarm changed to a a red and white shield and when I follow the direction it doe not do anything.
Just worked here on Android.
I just checked again and siren still not working for me. I tried it on my Samsung Galaxy and my rca tablet. I also did an update on my phone and tablet.
Reboot the base and verify that all firmware is up to date.
How do I reboot the base? I unplugged it and plugged it back in but that didn't change anything. Thank you for being so helpful.
The power cycle is a brute force reboot. Try both the app and a browser. Make sure your app is up to date and reboot your phone.
I appreciate all your advice. I did everything you said and I even reset the base and added my cameras back and turned off my cell and back on. I uninstalled my arlo app and reinstalled it and still no siren. I guess I will have to just live without it.
New App prolly' is buggy for now.. From time to time, try and Uninstall/Reinstall App or Logout/Login from your Profile Account and see if it fixes it.. If you can Re-install your previous version of App, that would be best for now until Arlo fixes these glitches in the next few weeks/months..
Thank you for your advice. I lI've in dense woods with a lot of bear so my alarm is very important to me. I will try everything you and others advise and hope it gets resolved.
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
