Ok so I have 5 Arlo pro cams and 2 Pro 2 cams.
The problem I’m having is that I set all the cameras in a “mode” and for about 24 hours all is good, I get my push notifications for all 7. The next day all but one of the cameras disappears from the mode. Why?
6 REPLIES 6
Don’t know why, but the first thing to do and easy is to reboot the base…
turn off then on , wait 2 mins for the reboot.
Ok I can do that.
So will all the cams be in the “default” mode or do I have to physically add them or after as well will I be able to create a mode with all cams?
Rebooting the base doesn't remove anything - you're just getting back to a known state.
Gotcha and I’ll go from there.
Still don’t understand the phenomenon...
I wonder if it has something to do with having two different series of cams and nit upgrading the base station...just a theory at this point.
The problem persists.
Only one camera triggered in the mode. Six are not present...
Hi DavidD58,
Are the cameras also showing missing from mode when you check on the web client from your computer?
