Ok so I have 5 Arlo pro cams and 2 Pro 2 cams.
The problem I’m having is that I set all the cameras in a “mode” and for about 24 hours all is good, I get my push notifications for all 7. The next day all but one of the cameras disappears from the mode. Why?
		6 REPLIES 6
Don’t know why, but the first thing to do and easy is to reboot the base…
turn off then on , wait 2 mins for the reboot.
						Ok I can do that.
So will all the cams be in the “default” mode or do I have to physically add them or after as well will I be able to create a mode with all cams?
Rebooting the base doesn't remove anything - you're just getting back to a known state.
						Gotcha and I’ll go from there.
Still don’t understand the phenomenon...
I wonder if it has something to do with having two different series of cams and nit upgrading the base station...just a theory at this point.
						The problem persists.
Only one camera triggered in the mode. Six are not present...
Hi DavidD58,
Are the cameras also showing missing from mode when you check on the web client from your computer?
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
