I have six cameras on the 99/year plan. Four Arlo Pros (night vision but no sound) and two Arlo Pro 2's (night vision and sound). The pros are freezing and not updating the images. The Pro 2's are working ok. This is on both iOS and in Safari. I've updated firmware on one of the cameras, plus the base station. What could still be broken?
Oh, and obviously I've rebooted everything.
Have you rebooted the cameras by reinserting the batteries? Also, try swapping a Pro and Pro 2 to see if it's the location that's causing the issue.
It's possible that a system reset is needed to set things straight. Remove all evices from Settings, My Devices. Use the Add Device selection in the Devices tab to claim the base. Sync the cameras. Update firmware as you go if prompted. Be sure to note settings, mode, rules and schedule before restting to speed rebuilding.
