All Arlo Pros frozen but Arlo Pro 2 are ok
  • 6 Replies
  • 1564 Views
jmzwebb
I have six cameras on the 99/year plan. Four Arlo Pros (night vision but no sound) and two Arlo Pro 2's (night vision and sound). The pros are freezing and not updating the images. The Pro 2's are working ok. This is on both iOS and in Safari. I've updated firmware on one of the cameras, plus the base station. What could still be broken?
6 REPLIES 6
jmzwebb
Oh, and obviously I've rebooted everything.
Have you rebooted the cameras by reinserting the batteries? Also, try swapping a Pro and Pro 2 to see if it's the location that's causing the issue.
jmzwebb
I just tried this. The Pro 2 continues to work right, but not the Pro. I should also mention that I *can* record video to the library using the Pro. But live doesn’t work, on either the web interface or iPhone. And I’ve had these things for more than a year, and they just started acting up maybe a month ago.
It's possible that a system reset is needed to set things straight. Remove all evices from Settings, My Devices. Use the Add Device selection in the Devices tab to claim the base. Sync the cameras. Update firmware as you go if prompted. Be sure to note settings, mode, rules and schedule before restting to speed rebuilding.
jmzwebb
I tried this, but the problem persists. The cameras will connect and record, but will not update live.
