  • 1 Reply
  • 1428 Views
Apokrinomai
Five cameras are on the first floor of my house.
When the alarm goes off, it triggers an audio alert on all cameras. As a result, we get several notifcations all at once and the app seems to respond more slowly as we try to determine the cause.
It also increases confusion, because all of the cameras have a reason to alarm.
Is there a way to avoid this?
You could try decreasing the audio sensitivity on all cameras. That would take some trial and error, setting off the siren while trying to change the sensitivity low enough to not trigger but high enough to be useful. And each camera would be different, due to distance and acoustics.
