  • 7 Replies
  • 2646 Views
LisaRue
Why does the access on my mobile phone app disconnect?
And then, in order to access it again, it requires a security code that is sent to my email, but which I have to access from a different screen on the phone.
So it always disconnects from the Arlo app briefly, and then instantly requires another security code - and the cycle continues.
Never able to provide the security code on the required screen, because of having to go to a different screen for the number!?  Oy.
How to resolve?
7 REPLIES 7
Normally you'd add the phone to the trusted device list.  Have you done that?
LisaRue
I have done that in the past, and then it seems to boot it out.
LisaRue
Not right away - it works for a while - and then stops accessing.
Go into Profile, then two-step verification.  See if the phone is in the trusted device list.
LisaRue
Yes, my cell phone is listed there as a trusted device already.
Is there a check next to the phone?
Maybe try removing and reinstalling the app.
If you have a PC, maybe check for the email verification on the PC, to eliminate the need to switch screens on the phone.
LisaRue
Thanks, I hope to try that.
Dealing with a sunroof that won't close before upcoming days of rain now.
