MY ARLO PRO ARE stuck at "getting information" SINCE YESTERDAY, I CANT CHANGE THE MODE, CAN SOME ONE HELP ME WITH THIS ISSUE
The base station field trial firmware to address issues with modes and schedules has completed with successful results, and we are releasing it to production. For more information, see our announcement.
New Base station firmware has been released that should help resolve the issue being discussed here. Check your base station firmware to be sure you are up to date with the latest available version.
Take a look here for more information on this firmware: Firmware Release Scheduled 6/21 to Address IR Rapid Battery Drain and Modes and Schedules Issues
Problem solved on my app,seems the new firmware suits.
\o/ \o/ \o/
Hope everyone will get their mode back 🙂
My Arlo Pro Base firmware has updated to 1.10.0.7_21310 , but when I used ISO app Arlo 2.5.4 the Mode still keeps saying "getting information". I've tried a lot of things, but I will give up now. There are more problems after firmware updated. I can't edit Mode with PC brower (Chrome). I can't change Mode with ISO app Arlo 2.4.0 and 2.4.9 . I am very disapointed.
FYI mine started working after the latest firmware update (iOS). I haven't tested all my other issues (wife geofencing not working, voice chat not working) but at least I can set the mode now!
Williamvarian,
I will reach out to you in a private message to gather more information.
SunnySD,
I've sent you a private message to gather more information on this issue.
Everytime I restart my Base under latest iOS App/Firmwares, It gets stuck in this mode "Getting Information".. I exit the App for a few seconds and it's back to normal.. If you say that this is fix, maybe for some but definitely not All... Bugs still floating around in this messy updates you talented Arlo Engineers put in this App/Firmwares... Also, I noticed my Base-Station's middle status light blinks when there's activity, which is normal at first coz' that's how it supposed to do the last time I checked... But for a few hours later, no more activity light blinking... So, is this new Arlo?.. Is it a Bug? A Bug fix? Which is it now?
I reseted my base today, added devices in Arlo app 2.5.4, and the Mode came back and it looks like ok, motion could be detected, and notification was pushed quickly, but no recordings in Library,and I can’t look live video of all cameras. Sometime the app report “The streaming service is reporting that the device is not streaming. Please check it ......” . Sometime the live video is severely stuck. It looks like communication problem. I restarted my modem router base station , it dose not work. Live video was ok some days ago. I don’t know the reason. I just have poor experience about Arlo.
When will this be fixed because contrary to anything posted here, this is not fixed. Going for a full year I take it?
I have the same issue -- I have 2 base stations -- one is okay to arm/disarm. The other is stuck on "getting information" -- I cannot arm it -- although I can view in in real time. I have tried re-booting the base station -- it did not work. Need help on this ASAP so I can arm these cameras.
jcraw29,
Is this behavior only happening when you try to change modes using iOS? Are you able to change modes using the web client?
Only says "getting information" from my apple devices -- 1 of my base stations I can access from IOS -- but other I cannot
jcraw29,
Try uninstalling the Arlo mobile app and download a fresh version from the app market. Log back into the app and try again. Do you still see the same issue?
I just tried to delete app and re-install -- still says "getting information" I can access it on my computers -- just not on IOS devices.
Why isn't this fixed yet?
iPhone X. Have completely deleted the app including deleting settings in iCloud. Restarted the station multiple times. It works fine on other devices, including ATV. Just not on iPhone X. Stuck on "Getting information".
Will this ever be fixed?
If you're still experiencing an issue with "Getting Status" after the above troubleshooting, please contact the Arlo Support Team to further investigate this issue.
