MY ARLO PRO ARE stuck at "getting information" SINCE YESTERDAY, I CANT CHANGE THE MODE, CAN SOME ONE HELP ME WITH THIS ISSUE
If you're still experiencing an issue with "Getting Status" after the above troubleshooting, please contact the Arlo Support Team to further investigate this issue.
Nothing can be changed in the Mode tag,only showing “Getting status..”, with both online and mobile app.
Same problem here! with both online and mobile app.
Same problem for me.
I have upgraded one of two iPhone to the new ARLO app. On the new updated iPhone I only see "getting information" in mode tap. Can't arm or disarm the system. The system is however online.
The other iPhone with the "old" ARLO app, is still working perfectly.
Restart of the home system didn't fix the issue.
Arlo PRO
HW system: VMB4000r3
Firmware: 1.10.0.4_20963
Do you mean the Modes tab? What app are you using?
This topic has been escalated and is currently being investigated by the engineering team. I will provide an update as soon as I have more information.
I can't view my schedule on my iPhone App, Safari Browser, and Google Browser.
Have tried to reboot basestation several times, with no luck!
Basestation firmware 1.10.0.4_20963
Browser Safari Version 11.1
iPhone IOS Version 11.3
Same here, cannot access Mode in iOS app. But I can access and change modes on my computer.
Very frustrating.
Hardware: VMB4000r3
Message: Getting information
Devices: Arlo Pro and Arlo Pro 2
Not everyone is having the issue but some do. It's being worked on.
After updating the Arlo app yesterday, I have the same problem since this morning. I try to reboot / turn off the base station and still stuck at 'getting information'.
Please help.
Have been having the same issue for days now. The system appears to be down to all of my devices.
had the issue for two days also...it appears to working 100% for me now.
I am also having problems with multiple IOS devices after latest Arlo update. (version 2.5.0). Cannot edit settings, only "Getting information". Tried to logout and reinstalling Arlo app. Works on a Windows platform.
Also tried to restart base station couple of times.
I am having this issue as well. I've reinstalled the app but still the same thing (iOS). Works on the web though, but I can't select geofencing from the web interface.
Arlo App Version: 2.5.0
OS: iOS 11.3.1
My Arlo pro wasn't functioning properly in the past 2 days. It has been
1) sometime the cameras are offine (unable to connect) &
2) the base station always at the "Getting information" stage
Please advise what is wrong and more important how to fix it?
A LOT of issues the past couple of weeks with ARLO's.
No alerts on current mobile devices.
Extremely limited streaming capabilities.
Can not connect to cameras even if only 1 is selected.
Recent updates (around May 8, 2018) resulted in 2 obvious outcomes. New coders or they are dropping support. You (and I) spent A LOT OF MONEY and netgear is scaling back.
Whole lot of issues Tech crew!
ARLO appeared to be a great fit... but now, not so much. I don't mind when a company has hickups but this just shows lack. Eventually, they may figure out the tech issues but for sure they will be reducing what they offer on new purchases. A lot of us spent good money to cover what we needed cover and thought was best. Netgear offered and changed up what they offered.
You are NOT the only one.
HAving the same probem. On the web I can see the status (but cannot control GEO) but on the app it showes "Getting information". I have restarted the base station / Power OFF - ON the base station / Delted the app / Rebooted my iPhone 8. Nothing works
Works again for me now on alla IOS devices. (same Arlo version) I dont know if Arlo did something on the server side.
I did however log in on my wifes Iphone with the previous Arlo app and there everything was working. Then when I loged in on my own Iphone and Ipad all was back to normal. Maybe a coincidence I dont know.
Still having the same issues. Its the app that cannot communicate with Netgear servers.
It started that I lacked notifications and when I looked into it the "getting info" started
Dont Netgear watch the support pages and reply to this kind of messages?
How can I get in touch with technicians @ Netgear... seems impossible... or?
Ok, down again. Works on my wifes older arlo version and windows. Not in v2.5.0 on my iphone or ipad. Cameras work and send notification but cannot change modes or see status.
Come on, sort this out!
