Has anyone figured out why the Arlo Pro stopped recording videos to library?
I've had the Pro, with 4 cameras working for about 5 years and suddenly stopped recording 3 days ago on May 10 at 1am.
-Live feed still works, so no issues with the cameras.
-System Mode is "Armed" -All camera rules are armed for audio and motion.
-I toggled between "Disarm" and "Armed". Still nothing.
-I Reset the base with the Pin hole button. Still nothing.
-I unplugged for a minute and repowered on. Still nothing.
-I dont have a Subscription, but this is the Pro which gets the free 7 days storage for "Life".
-Cameras are wired with full time power connection.
-I unplugged all cameras and plugged back in. Still Nothing.
Ok, I just read other posts, and Here is how to fix this.
Remove the Base Station device from your App, and then re-Add the base station and cameras like the first time installing.
This worked.
This worked.
I had the exact same issue, but it stopped working on May 8th, 2024. Like you, I tried all the options provided online and nothing has worked to resume the local recording.
Thank you!!!!!!
This worked for me as well. Appreciate you posting that follow up.
No-one seems to be asking the question why that is. I smell a rat why one has to remove and onboard their cameras again.
Thank you for your info. It worked for us as we had the issue of our 3 cameras not recording for 3 days now. Your solution worked!
