2 Arlo Pro Cameras - 1 NOT sending Alerts & 1 does
  • 5 Replies
  • 3433 Views
  • 2 Likes
hjbrady1
Two  Pro cameras are connected to base station, both have motion-detection enabled and BOTH are successfully recording video to cloud but only 1 sends alerts to my email.  Any suggestions?
Yes, the eamil addresses and push ( toggles ) are in the MODE
mode/ armed-edit
5 REPLIES 5
email settings are PER camera..make sure the camera has the proper email address and toggled on
hjbrady1
I am using the Netgear Arlo website (not smartphone app) ... Individual camera settings has no field for email.  Only settings under Camera are: On/Off; Battery state; Connection & Camera LED.  My email address does appear under Settings for Base Station.  Is there some other menu or pull-down that I'm missing?
mode/ armed-edit
hjbrady1
THANK YOU !!!   You were spot-on ... discrepancy between the two cameras.  I made the change BUT must wait until I get home to trigger recording.  Will close out and click RESOLVED button then!
hjbrady1
Just got home and jumped in front of camera ... PROBLEM SOLVED!!  Thank you
