Two Pro cameras are connected to base station, both have motion-detection enabled and BOTH are successfully recording video to cloud but only 1 sends alerts to my email. Any suggestions?
Yes, the eamil addresses and push ( toggles ) are in the MODE
mode/ armed-edit
email settings are PER camera..make sure the camera has the proper email address and toggled on
I am using the Netgear Arlo website (not smartphone app) ... Individual camera settings has no field for email. Only settings under Camera are: On/Off; Battery state; Connection & Camera LED. My email address does appear under Settings for Base Station. Is there some other menu or pull-down that I'm missing?
mode/ armed-edit
THANK YOU !!! You were spot-on ... discrepancy between the two cameras. I made the change BUT must wait until I get home to trigger recording. Will close out and click RESOLVED button then!
Just got home and jumped in front of camera ... PROBLEM SOLVED!! Thank you
