1 of 5 Cameras keeps dropping offline every two or three weeks
  • 17 Replies
  • 7292 Views
  • 2 Likes
  • 7 In Conversation
DaveMostats
Of the five Arlo pro cameras I have, one keeps dropping like every two or three weeks.  The battery’s all tend to last about a month.  But, this one camera will work fine and then just goes offline.  I haveve to bring it down, take the battery out, reinsert the battery and then resink it.   Then put it back up and it will work fine for another two or three weeks.  I even moved it closer to the router.... like 5 feet away.  All the other cameras work fine and I am very pleased.  I got this at Christmas, so it’s less then 8 months old.    What do I do?
Any suggestions or help will be greatly appreciated.
Dave
ShayneS
DaveMostats,
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
17 REPLIES 17
DaveMostats,
It sounds like there could be an interference or range issue that is causing that camera to have trouble maintaining it's connection with the base station. Try swapping the location of that camera with one of the cameras that works fine and test. This will help isolate the issue to being a problem with the camera or the cameras location.
DaveMostats
Attn: James C.
As stated before, the camera was great for like 6 months.  Then, for no apparent reason, it simply goes off line... about every two to three weeks.  Move camera to different locations with same results.  The last time was about 10 feets from base station. And like before, works great for like two or three weeks, then simply goes offline.  Have to take the camera battery out, push it back in and set the camera next to the base to syn.  Everything works fine for another two to three weeks.
PLEASE....... Help me.
David Mostats
PS.... the other four cameras work great, regardless of where I put them.
MPooh-1
I have the same problem. It was a 4 set package. About once a month 2 cameras say off line the other two are fine. Change batteries and resync. Nope 2 are still offline! Grrr frustrating!!!
ShayneS
MPooh-1,
Where are these two cameras located from the base station? Have you tried to move the base station or router further from each other?
DaveMostats
Ok....  so upset..... 2 email reply’s to my problem and both said the same thing.   Move it closer to a location that works.  It’s in the text, that I moved it to a location 5 feet from the router and it still drops after a week or two.
Going to put this on Facebook. Maybe some one there can help me.
Dave
DaveMostats
I have moved the camera to several locations, one was 5 feet from the base.  I think that there might be a short in the camera.  Each time, when it goes out, I put in a fully charged battery and the one I take out is empty.  The other cameras will go up to 60 days between charging.  So I need to find out what I can do about replacing this camera.  It’s still under warranty but I have been trying to get this fixed since last April.  The warranty will be out in two months.
So.... what do I do?
David Mostats
ShayneS
DaveMostats,
davidjamesbull
this should not be marked as solved... is the plan to share the fix with the broader audience?
ShayneS
davidjamesbull,
What is the issue you are experiencing with your camera?
davidjamesbull
Same as described in this thread.  Camera keep saying the device is offline...  Take it down, resynch, get it working, put it back in place, drops a week or two later.  Not sure of the time frame.  Currently about 30 feet away.  I'll be trying the 10 foot test next.
Tsc14
I’m having the same problem with 1 camera and mine are about a month old.. I’ve reset it 2x and today makes 3. I feel it is a defect in the camera. What says you Arlo employee?
Tsc14
Here is a pic of the issues.
ShayneS
@Tsc14
Have you made any changes to your router or base station placement? There may be some interference happening within the area. Have you tried to reboot your router? Is there a possibility you can move the trouble camera inside closer to the base station and test again?
Tsc14
This camera is 12ft away and is in visible sight of the base. The other 3 are more than 25ft away. Moving this camera would defeat the purpose of having it there. I did cycled my router on Saturday, because my computer was lagging. The issue popped up today. This is the third time on the same camera.
ShayneS
@Tsc14
Is it possible to swap locations with the camera to see if this issue stays with the device?
Tsc14
I can swap with a camera that is farther away and has more obstacles in its way.
