Can't set push notifications
  • 6 Replies
  • 3515 Views
RobT7
Hi... for some reason, some of my cameras won't let me set a push notification, only email???  Anyone else see this and have a solution?  Thanks!
6 REPLIES 6
ianinaus
Yes me also since last app update here in Australia. I have contacted Netgear twice each time they deny any issues and get me to undertake extensive troubleshooting.
ShayneS
@RobT7 @ianinaus
Are you having this issue on the web portal or the Arlo Mobile App?
RobT7
Ahhh... Thanks!  It doesn't work on the web portal, but I hadn't thought to try to Mobile app.  It works there.  Thanks again.
ShayneS
@RobT7
Is this a custom mode you are having the issue with? Can you try and re-create the mode & test the push notification again.
RobT7
No, it was the standard "armed" one.
ShayneS
Have you tried a different browser as well? I would like t try and find out if this issue occurs on all browsers or just one fro you?
