Hi... for some reason, some of my cameras won't let me set a push notification, only email??? Anyone else see this and have a solution? Thanks!
6 REPLIES 6
Yes me also since last app update here in Australia. I have contacted Netgear twice each time they deny any issues and get me to undertake extensive troubleshooting.
Ahhh... Thanks! It doesn't work on the web portal, but I hadn't thought to try to Mobile app. It works there. Thanks again.
Is this a custom mode you are having the issue with? Can you try and re-create the mode & test the push notification again.
No, it was the standard "armed" one.
Have you tried a different browser as well? I would like t try and find out if this issue occurs on all browsers or just one fro you?
