  • 9 Replies
  • 1089 Views
montyfabio
Hi,
i have 4 arlo pro 5
i disabled audio detection from the active routine from all 4 cameras but i still have feed full of audio recording, where am i wrong?
ShayneS
@montyfabio Turning this off should alleviate the symptom your experiencing.
9 REPLIES 9
ShayneS
Hi @montyfabio
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
montyfabio
I've temporarily solved it switching to "Arm Home" mode.. it seems that in that mode the audio detection off actually works..
i haven't had many trubleshooting.. i turned on audio detection and saved.. turned off again and saved.. i turned off microphone on the camera settings.. but seems that in "arm away" audio detection is always working.. in "arm home" it works as i want
ShayneS
@montyfabio
Can you PM me with the last 4 digits of the serial number on the cameras showing Audio recordings in your feed as well as a screenshot of the Audio clips in the feed?
ShayneS
Thanks for the info @montyfabio
I notified the appropriate teams and I will reply back with more info as soon as possible.
ShayneS
montyfabio
Yes.. i found that menu.. maybe it's that "other sound"?..
Gosh is a very hidden menu I would never found it without a guide..
I try deactivating it
ShayneS
montyfabio
yes, it solved the problem
ShayneS
Thanks for the update.
