Can't use arlo secure
Hello,
I’m new to Arlo and could use some assistance. I have the Arlo Pro 5S 2K, and I attempted to add a new device to the Arlo Secure app on iOS. However, I encountered an issue where I'm prompted to upgrade to the Arlo Experience, which hasn’t been released for my region yet. Is there a way to continue using the Arlo Secure app to add new devices? Additionally, could you clarify what features I would have access to on the app without a subscription?
Thanks!!
Buli24,
Where are you located? If you're prompted to upgrade the app, you should be able to proceed with the upgrade. Did you receive an error message that prevents you from progressing through the upgrade flow?
For more information on what features you'll have access to without a subscription, see here: https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-trial-ends
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
