Pro 5S 2K app and manual
I did a quick Google search on "arlo pro5s manual" and came up with this one that refers to the user interface you're using:
https://downloads.arlo.com/en-us/support/docs/arlopro5/202-50038-01_Pro5_UM_2dec2022.pdf
The same one shows if I go to the Pro 5 support page and get the user documentation from there.
Yes, and it does contain the errors that @BGL24 talks about. It would be good if it got updated.
Thank you for bringing this to our attention, it is being looked into.
The app doesn't match the current hardware either. It calls for the use of buttons that don't exist. And then the User Manual still doesn't match and it is written like one must install a base station when all the sales literature says that it isn't required. ARLO really needs to get its act together.
Thank you, we appreciate you bringing this to our attention. It is being looked into.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
