Pro 5 cameras will not recharge
  • 10 Replies
  • 2510 Views
Kevin1951
My pro 5 cameras will not recharge. I’ve tried all the fixes on Arlo site but to no avail. I suspect charging lead?
10 REPLIES 10
What charging cable are you using?
Do you see any LED behavior when plugging in the charging cable?
Kevin1951
Thanks for responding. I use the lead supplied with the cameras.
There are no lights. If I keep trying it may flash once.
Kevin
Kevin1951,
Is this the same behavior with more than one camera or just a single camera?
Kevin1951
It’s the same with both cameras. They had flat batteries for a while (3 months) as I had health problems and could not attend them.
Kevin1951,
This could indicate a hardware issue. I encourage you to reach out to the Arlo Support team to further investigate these symptoms. You can find support contact options within the Arlo Secure mobile app under Settings > Support Center
Kevin1951
As well as my camera ongoing problems, initially my base station was down, I eventually resolved this by going through arlo support and finally doing a factory reset which has worked. When I try to add the cameras in can’t find them because of the flat batteries.
kev
Kevin1951
Problem not resolved
Kevin1951,
I encourage you to reach out to the Arlo Support team using the Arlo mobile app under Settings > Support Center and open a ticket to further investigate the issue you're experiencing.
Kevin1951
I’ve moved the charge plug and cable to another plug in the house and blue light flashes about 4 or 5 times and then stops. Is it charging?
If the flashing is immediately upon applying power from the charger, it should be charging. The battery icon should also indicate this by displaying a lightning bolt across the battery. It typically takes ~3 hours to charge the battery.
