Do privacy zones work with this camera? Every time I try to add one it never saves.
Just tried it here and had no problems. You're using Activity Zones and then clicking on the "+" at the top right, correct? ANd then using Save at the bottom?
Wakamula,
I was not able to replicate the issue you're describing when adding activity zones. Are you still experiencing the issue today?
For more information on activity zones and how to add them, see here: https://kb.arlo.com/1001908/What-are-Arlo-Activity-Zones-and-how-do-I-create-them
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
