No recording but smart hub is enable
  • 4 Replies
  • 931 Views
Kenny7522
Hi,
I am a new user and using
Camera: Pro5
Smart hub: VMB4540
USB: SanDisk 512GB Ultra Fit USB 3.2 Flash Drive
Subscription: No
The camera and smart hub connected to wifi.
Smart hub record locally.
storage status is good.
Port forwarding is enabled and available.
Camera has notifications when motions detected in Arm mode.
But there is no recording.
Nothing in Feed.
Even I tried to reinstall all the app, camera and smart hub.
it still can not record any video.
Anyone can help me?
thank you so much.
Kind regards,
Kenny
WLynne
Nothing in Feed.
Local recordings are not shown in the Feed.
To see them you need to
  1. go to the devices page
  2. select the base
  3. select "storage settings"
There is a bug in the iOS app, so port forwarding won't actually work with iPhones and iPads.  It will work with Android.
Kenny7522
Thank you WLynne.
it looks messy in Pro5.
Kenny7522
Thank you StephenB,
In storage settings, there is 0 storage used in the USB disk.
I think the app has something problem? As the motion detection is work. But no video recorded.
