Hi,
I am a new user and using
Camera: Pro5
Smart hub: VMB4540
USB: SanDisk 512GB Ultra Fit USB 3.2 Flash Drive
Subscription: No
The camera and smart hub connected to wifi.
Smart hub record locally.
storage status is good.
Port forwarding is enabled and available.
Camera has notifications when motions detected in Arm mode.
But there is no recording.
Nothing in Feed.
Even I tried to reinstall all the app, camera and smart hub.
it still can not record any video.
Anyone can help me?
thank you so much.
Kind regards,
Kenny
Hi, You might want to check out the board noted below.
But there is no recording.Nothing in Feed.
Local recordings are not shown in the Feed.
To see them you need to
- go to the devices page
- select the base
- select "storage settings"
There is a bug in the iOS app, so port forwarding won't actually work with iPhones and iPads. It will work with Android.
Thank you WLynne.
it looks messy in Pro5.
Thank you StephenB,
In storage settings, there is 0 storage used in the USB disk.
I think the app has something problem? As the motion detection is work. But no video recorded.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
