Mounting Options Arlo Pro 5S 2K
  • 1 Reply
  • 520 Views
JDLT11
Cameras come with the Antitheft mount and does not have a 1/4 20MM screw mount, are there other options to use a polo mount along with the solar panel that does have the 1/4 20MM screw?
Best answers
  • StephenB
    You don't have to get one with the antitheft mount.
    But if you have one and can't return it, then you could get a replacement housing that will handle the normal screw mount:
