Mounting Options Arlo Pro 5S 2K
Cameras come with the Antitheft mount and does not have a 1/4 20MM screw mount, are there other options to use a polo mount along with the solar panel that does have the 1/4 20MM screw?
Best answers
You don't have to get one with the antitheft mount.
But if you have one and can't return it, then you could get a replacement housing that will handle the normal screw mount:
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
