Link accounts
  • 1 Reply
  • 2151 Views
mshebaily
I have two Arlo accounts. Is there anyway to merge them together so I don’t have to swap back-and-forth from accounts to look at all my cameras?
You have two options.
One is to use the friend account feature to share the cameras from each account with the other.
The second option is to set up a second location in one of the accounts.  Then remove the cameras (and base if you use one) from the other account, and reinstall the equipment in the first one.  After that you can delete the unused accounts.
There are some camera settings you cannot change from a friend account.  The second option gives you full control over all the cameras from one account.   Either way, you will need separate subscriptions for each location.
