Arlo Pro 5 Battery Loses 20% of charge overnight when offline/device off
I just bought new Pro 5 cameras. I have setup and am testing one of these before opening the others.
The camera seems to work fine, but overnight, after ensuring that the battery charge is 100% at end of night, I have turned off (via Device Off on app) and disconnected the camera (no wifi), and then the battery status is ~80% the following morning when I turn it on. In other words, it is losing ~20% of charge overnight with no activity.
When it is off and offline, I can still hear some activity in the camera - like it is trying to 'click' on.
It has the latest firmware from update on set up. Please advise....
Best answers
Bring it closer to your router or hub to see if that helps. Distance and/or other 2.4GHz wireless devices nearby can cause this. Also, how many recordings were made during that 20% time period? If they total well over 5 minutes (the spec is for <5 minutes total per day) that could be the reason.
The click may be concerning. If you point the camera towards a blank wall, does it continue?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
