I have two Arlo accounts. Is there anyway to merge them together so I don’t have to swap back-and-forth from accounts to look at all my cameras?
You have two options.
One is to use the friend account feature to share the cameras from each account with the other.
The second option is to set up a second location in one of the accounts. Then remove the cameras (and base if you use one) from the other account, and reinstall the equipment in the first one. After that you can delete the unused accounts.
There are some camera settings you cannot change from a friend account. The second option gives you full control over all the cameras from one account. Either way, you will need separate subscriptions for each location.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
