Pro 5 Camera not show as option to connect in Mauritius
Hi
I have purchased 2 x Arlo Pro5 cameras to use in Mauritius. We have set up a new account but when we go to add device (on iPhone / iPad) it does not give the option to add a Pro5 camera, please help / advise
will these cameras work in Mauritius?
There's only a limited number of countries that can get subscriptions so it's likely you need to return the cameras. You can use a VPN server in a country that does get subs to set the system up and use a credit card from that country to purchase a plan when the trial sub expires. After setup, you don't need the VPN.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
Hi
Ok, set up a VPN in Europe, deleted initial account, set up new account using VPN and yes, the PRO 5 now comes up as an option to add, HOWEVER, when I go to add camera, go through all the steps (put the local wifi details) and it then will not find the camera after searching for it, very annoying… so the VPN has given the option in the app to add the Pro 5 but then will not recognise it once I log into the wifi network in MU (which is 2.4) any other suggestions..?
@RMG-7 wrote:
Hi
Did you turn off the VPN after you created the account? It needs to be off during the actual install.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
