I cannot get this to hook up to my phone
@Tammy65 wrote: I cannot get this to hook up to my phone
To be clear, the camera doesn't "hook up to your phone". You do use either the phone or a computer to add it to your account. But the camera is either connecting to the internet through an Arlo Hub, or it is connecting directly to the internet through your home wifi.
Do you see the ability to add a Pro 5s camera when you go into the Arlo Secure App and then go to the devices screen and press the "+" sign at the top?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
