Issues with Siren
Hi All,
Just wondering has anyone have an issue with setting of the sirens through the app, manually.
I have been having issues since September, 2024.
The team at Arlo can not seem to fix the issue. just wondering if someone has the same issue.
@BeeSec wrote:
Hi All,
Is this happening with the Pro 5s camera (or a different model)?
Is the camera paired with an Arlo hub, or is it connected to your home wifi? If you are using a hub, what model is it?
I have a variety of cameras, including the Arlo Essential, Pro 4, Pro 5, and Arlo GO 2—about a dozen in total. I've been working with the Arlo support team since September, going back and forth to troubleshoot, and nothing is fixed. Now I realize I'm not the only one experiencing this issue.
No hub, prior September i had no issues.
Can you activate the sirens from a different handheld device?
NO !!
i have tried mulitpul devices, from Android to Apple
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
