Issues with Siren
  • 5 Replies
  • 330 Views
BeeSec
Hi All,
Just wondering has anyone have an issue with setting of the sirens through the app, manually.
I have been having issues since September, 2024.
The team at Arlo can not seem to fix the issue. just wondering if someone has the same issue.
5 REPLIES 5
@BeeSec wrote:
Hi All,
Is this happening with the Pro 5s camera (or a different model)?
Is the camera paired with an Arlo hub, or is it connected to your home wifi?  If you are using a hub, what model is it?
BeeSec
I have a variety of cameras, including the Arlo Essential, Pro 4, Pro 5, and Arlo GO 2—about a dozen in total. I've been working with the Arlo support team since September, going back and forth to troubleshoot, and nothing is fixed. Now I realize I'm not the only one experiencing this issue.
No hub, prior September i had no issues.
ShayneS
Can you activate the sirens from a different handheld device?
BeeSec
NO !!
i have tried mulitpul devices, from Android to Apple
ShayneS
@BeeSec
Is the Shield logo missing or are they not alerting after Activating the siren?
