We've been having a lot of issues with our Arlo system lately. Mainly geofencing failures, but we've discovered a new issue.
The feed I get (both on the app and on web browser) is different to that of my wife's. She get additional clips coming through.
Both of us have full admin access to the system so there is no config difference.
Anyone seen this before?
@Retired_Member wrote:
BTW She is listed as having "Admin" access in the web portal. She can change modes, but can't change the criteria.
That gives her some controls, but as you found, not all of them.
If you want to give her full control, just have her use your account credentials.
I have full and proper access to all cameras in the feed, as does she.
Understood. But did you double-check the feed settings?
- press on the three dots in the upper right hand corner of the feed page
- select "feed settings" from the pulldown
Make sure both "Event Types" and "Devices" are set to "All".
Are you saying you are both using the same credentials?
Shared accounts do NOT have full admin access, even if you used "grant access" when the cameras were shared.
I'm saying that I share access with my wife (invited her email address) and give her control over the system too.
In any case, why does she get more recordings than me, for the same cameras??
She shouldn't.
Have you double checked your feed settings? They are persistent, so if you forget to go back and select all, then there will be recordings that you don't see.
Yep you would think. I have full and proper access to all cameras in the feed, as does she.
Also I have noticed that I will often get a notification of motion at a camera, but nothing then appears in the feed.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
