Can Pro 5 connect both to WiFi and hub?
Hi!
I have three Pro 5S cameras today that connects to my WiFi (meshed also with outdoor access point for better range).
I have a subscription for all cameras to use cloud storage.
Now I'm thinking of adding two Ultra 2 cameras. What I understand is that they require a hub (and a hub is included in the package).
So, they do not connect directly to my meshed WiFi. But it also adds local storage which is good.
Question 1: Is it only local or will it use cloud storage as well? Is the hub syncing to the cloud?
Question 2: Can my existing Pro 5S cameras also connect to the hub and use the local storage and at the same time be connected to my WiFi for cloud storage, I guess not?
The reason I ask is that I think maybe one of my cameras will be out of range from the hub, but then I guess that camera can still use my WiFi, but without local storage in that case. Am I right?
BR,
Håkan
If you have a subscription for the cameras, then you will get both cloud recordings and local recordings.
The hub does not "sync to the cloud". All motion-triggered (or audio-triggered) recordings will be saved by the hub, and are simultaneously sent to the cloud. In general, you will find local recordings that are not in the cloud. For example, if you use activity zones, out-of-zone recordings will be saved locally, but will not be in the cloud.
No, the cameras need to be connected to the hub wifi in order to get local storage.
FWIW, I've suggested to Arlo that they should allow cameras to connect to the hub over home wifi. My mesh has much better coverage than my bases, and it'd be nice to take advantage of that w/o losing local storage.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
