Arlo 5s cameras connecting
Can not get my arlo 5 cameras to connect to my UNIFI wifi access points. Have set wifi to 2.4ghz. Spent total of 4 hrs on chat with support with no luck.
mikecampbell,
What LED behavior are you seeing when you attempt to connect the cameras? How far along are you able to get in the app before onboarding fails?
After scanning the QR code the blue light flashes for about 5 seconds then stops. Support had me factory reset the cameras but didn't help.
As a side note I needed a camera where I don't have wifi coverage, so i purchased a wifi hotspot from verizon and it set up that camera with no issues.
mikecampbell,
Try checking your security type within your router. Change to WPA2, if it's not selected already.
Also try checking to see if there are any additional firewall settings enabled.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
