Arlo Pro S5 not fully charging
I am one of the Arlo users that was forced to move to newer cameras as the ones I had were at end of life. I looked at options and because I was familiar with Arlo decided to stick with it and spend the money to move to the latest version. I am definitely rethinking my decision. The batteries won't charge above 50% in any of the cameras including the spare battery I purchased. I have tried everything and am pretty sure it has to do with the charging cable/unit. They want me to take the cameras down that I have installed and do factory reset on them all. I have spent enough time on this issue and refuse to do any more for NEW cameras! If anyone else has experienced something similar please share as I am considering sending them back and going with another company by end of day.
Arlo Pro 5
charging unit
Tech513,
Are you using a solar panel or a standard charging cable? Are the cameras in use while charging?
What happens once they reach 50% (does the charging indicator in the app no longer indicate that the camera battery is being charged)?
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
