Alro pro 5S 2K camera feed when using local storage
  • 1 Reply
  • 2061 Views
geoano
My Arlo Pro 5S 2K camera is connected to a base station, model VMB4000r3. The camera is set to record to the local storage in the routines but it seems the recordings are not saved. My questions is if the camera is compatible with this base station as it is of an older version. Contrary according to Arlo the base station is compatible otherwise, i guess it wouldn't connect to it at all. It was working ok while in the subscription trail period and i want to avoid using subscription and saving recordings in the cloud.
Edinburgh_lad1
Hero
Hero
If you have Feed, as opposed to Library, local recordings aren't going to show there.. To access your recordings if you have Feed, you have to go to Devices > base station > local storage.
But with your particular base station, the only way to view recordings is to view them on a pc.
