How to replace battery in pro 5s?
how to replace battery in pro 5s.....8 months is a JOKE... NO BUTTONS....INSTRUCTIONS STATE TO JUST SQUEEZE THE BODY AND CAMERA SLIDES OUT.....YEA RIGHT....
There is a release button on the bottom of the pro 5s. See page 78 here:
You often do need to (carefully) shake the camera to get the housing out of the shell.
If it is sticking, you can get some silcone grease, and apply it to the O-ring after you get the camera out.
if there is no button on the bottom of the camera, then you must have an Essential model (not a Pro 5s).
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
