Alro pro 5S 2K camera feed when using local storage
My Arlo Pro 5S 2K camera is connected to a base station, model VMB4000r3. The camera is set to record to the local storage in the routines but it seems the recordings are not saved. My questions is if the camera is compatible with this base station as it is of an older version. Contrary according to Arlo the base station is compatible otherwise, i guess it wouldn't connect to it at all. It was working ok while in the subscription trail period and i want to avoid using subscription and saving recordings in the cloud.
If you have Feed, as opposed to Library, local recordings aren't going to show there.. To access your recordings if you have Feed, you have to go to Devices > base station > local storage.
But with your particular base station, the only way to view recordings is to view them on a pc.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
