Arlo Pro 5 2K not connecting to telstra router
  • 1 Reply
  • 1024 Views
Jemo
I have a telstra smart hub router.  Bought 2 Pro5 cameras and they wont connect.  Have tried disconnecting 5hz wifi plus connecting through guest wifi setting.  Still wont connect. Dont have a Arlo hub.
  1. Check that the security is WPA2 (AES).
  2. double-check that the phone is connected to the same network you want use for the camera.
  3. If you use a VPN, then make sure it is turned off
  4. If you have unusual characters (accents, etc) in the network name or password, then try removing them.
