ARLO PRO 5s - Indian region
Hello Arlo Support Team,
I recently purchased the Arlo Pro 5S camera, but I am facing an issue with setting it up in the Indian region. When I try to configure the camera using the Arlo Secure app, the Pro 5S model does not appear under the "Pro Cameras" section, making it impossible to proceed with the setup.
I’ve made sure that I am using the latest version of the app, but the issue persists. I’m wondering if this is a region-specific problem, as the Pro 5S seems to be missing only in this area. Could you please clarify whether the Pro 5S camera is currently supported in India? If not, when can we expect an update to add support for the Pro 5S model in the app?
I would appreciate any information regarding a timeline for this fix or updates that will address this issue.
Thank you for your help!
You need Arlo Secure to operate Pro 5, and it's not available in all regions.
I have Arlo secure app and pro 5s camera model is not enabled in this app, if you download the app from India.
There is not a solution so far !!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
