Will usb extender work on Arlo pro 5s?
Hi everyone, I just purchased 6 Arlo pro 5s from amazon. The charging cables come with it is very short. I am wondering if I can use some usb extender with it instead of buying 6 expensive Arlo charging cables .or is there any alternative solution with it ? I happened to purchased 6 Arlo camera on amazon (50% off) 2 weeks before price drop (64% off), which cost me extra $130. Looking for ways to save some money on those cables
Cables are relatively cheap but a quality extension cable should work fine. Cheap ones use thinner wires which can create their own issues. Keep the length as short as possible, too.
It is a proprietary cable with the magnetic connector, and Arlo only sells the 8 foot length you already have for indoor use. The only other option from Arlo is to get the 25' outdoor cable+charger - which is fully integrated, so the cable does not detach from the charger. Wasserstein sells a 25' outdoor cable that is not integrated with their charger, so you could also try that. I've never tried any Wasserstein products, so this is just an FYI and not a recommendation. While an extension cable might work, I don't recommend that if you want to use the cameras outdoors.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
