All three are arlo 5's all are powered and the app confirms they are plugged in yet they show low power mode. One was at 2%, yet never did run out of power, stayed like that for days. Another is at 9% and another fully charged yet went into low power mode and only recorded snapshots. These arlo 5's are the most unreliable off all the different cameras. I have a few 4's and HAVE NEVER, had an issue with them. The 5's are constantly offline, now go into low power even though plugged in. Anyone have any clue why? I am reluctant to engage support as they have proven to be absolutely worthless and ask questions which are totally irrelevant to the problem. I always feel like I am chasing my own tail dealing with them so maybe someone on here has an idea what the issue is. And yes, I am seriously considering ditching all of them (I have 16 cameras across two homes). So fed up with Arlo after 8 years of agony.
low power mode
Can you please send me a dm of the email the Arlo account is set up on?
and how exactly do I do that?
You send a dm by clicking on the envelope icon on the top right of the forum page.
I got that much yes but to who as you don’t come up when I search for your name
You can enter Brooken manually after you click on "new message".
Alternatively, click on her username in one of the earlier posts, and then click on "send this user a private message" on the right side of the page.
What was the point of sending a dm? It’s been crickets ever since.
@Retired_Member the behavior you are seeing with the Pro 5 taking snapshots instead of recordings is a behavior we are aware of. The firmware rollout has started and should be completed in the next few weeks. As soon as that firmware is full rolled out that behavior will be resolved. As for the reason they are going into low power mode when fully charged please reach out to support. You can get there within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing. .
Thanks. Regarding the low power mode I’ve had several cameras in two different homes drain to under 5 % while plugged in and the charging indicator is on. The only way for the camera
to start charging again is to remove the battery and power plug and restart the camera it then starts charging again although very slowly. This is not a specific one camera issue but three across two homes. Very odd. It’s not recording causing this battery drain. Why would it drain the battery so quickly when plugged in. It does however never go below 1% so this is something new to investigate. If there is something from me that can help let me know but support most likely will just ask me to restart the camera which I have already done. Cold start did the trick. Warm restart did not!! Maybe that helps.
Let me research this a bit and then I will reach back out to you. I am going to send you a dm for more information as well.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
